Add the ability to select surfaces and design view representations for inclusion in iPart members, in the same way that work features can be included.
Surfaces should have consistent geometry references between rebuilds/member generations so that constraints are not broken. It would be great if the appearance of a surface could be maintained in the generated member.
Included view representations should cause the members to regenerate when they are modified. The representations can be locked (present functionality) which can help prevent accidental member regeneration due to view changes.
Also consider options to include new functionality such as level of detail.
cadull
