I want better error reporting when a cyclical constraint error is found.
Show involved features, sketches, constraints that form the cycle so the user is able to understand and fix the problem.
See post :
http://forums.autodesk.com/t5/Inventor-General/Top-Down-IPT-Assembly-Error-Is-Inventor-lagging-behin...
3 Comments
CJ.10E-10mm
When Top-Down Modelling with numerous solid entities it would be greatly beneficial if instead of providing a 'bland' cyclical error warning, the same highlighting facility could be provided similar to that provided with constraint errors. Thus identifying the actual solids in question.
Thank you.
CJ
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
