Show only
Search instead for
Until it is added here's a blog post of mine that has an iLogic rule to do this. (It also asks to select a file to replace part references as well, but you can just select the same part if it doesn't need to be replaced.
It is possible to copy / past sheet from one idw to another one. But it is not possible to do this operation in a single idw. I would very much use this function.
Make it possible to copy / past sheet within single .idw file.
This is crazy. How can this not be an option? I have to copy the sheet into some new drawing and then copy it back? Come on AutoDesk, do better. We all know you can. Its almost as bad as not have spell check. Almost.
This is absolutely necessary. I was really hoping to find out that 2019 was the version we got this feature, and am more than a bit disheartened to see that this was posted in 2014, accepted in minutes and four years later is still not done.
The workaround steps are somewhat ridiculous: Copy Sheet. Create New File. New Drawing. Paste Sheet in New Drawing. Copy Sheet in New Drawing. Go back to original drawing. Paste.
It would be good to be able to duplicate existing sheets in an Inventor drawing. Currently, this can only be accomplished by copying sheet to a new drawing and then copying it back to the drawing of interest. should be able to duplicate sheet in right-click drop-down menu.
Inventor should provide a check in option during change of units permiting the drawing to scale automatically with dimentions. i.e, if a line of 10mm is drawn, when units are changed to inches the drawing should get a check in permisivity to change its scale to 10inches
This isn't something I've needed to do that often. But when I have needed it, the necessary workaround was really annoying. Voted because this is a seemingly unnecessary, silly limitation.
Inventor is full of workarounds because if everything worked as we wanted we wanted, I wouldnt hold my breath but hopefully Aaron/whoever makes a trip about the ideas soon.
