Add CTRL behavior to Horizontal and Vertical sketch constraint.
If you choose a horizontal constraint and you realize that you need a vertical constraint, then you need to select the vertical constraint.
Despite the fact that we are now in 2015 get a preview to see what is horizontal or vertical.
Add a CTRL action, so that horizontal changes to vertical as soon as you press the CTRL.
Ditto for vertical to horizontal constraint.
85 Comments
Cadmanto
Rusty,
While I did not know what JD shared with you, this is one of those things that is not painfully obvious.  Thus the reason why you, I and Neil did not stumble upon this earlier.  Actually this almost falls under the category of tips and tricks.
Thank you for sharing this.  I will definately take a look at this myself next time.
Still does not take away that this functionality does not need improvement.
cadull_rb
Another option is to display the coordinate system indicator for sketches. The X axis is horizontal and the Y axis is vertical.
sales
I've just tried that, - the view cube orientation has no correlation to the
horizontal and vertical constraint, - after-all the view cube can be
rotated and set independently of the UCS.
Try rotating the sketch and see what happens.
All I'm trying to do is to make 'drawing' the sketch easier.
Thus in sketch mode:
If I draw a line and wish it to be horizontal when viewed on the screen -
I'd like to just hit the horizontal constraint and constrain it
horizontally.
The current issue I have is that sometimes, and dependent upon view
rotation, - If I draw a nearly horizontal line (not auto constrained) near
horizontal line and wish it to be horizontal when viewed on my screen
(irrespective of the UCS and view cube orientation) - to make the line
horizontal I need apply the vertical constraint !!!!!!
Try rotating the sketch and experimenting with drawing and constraining
lines.
​Mark​
The Digital Forge, Langford, Biggleswade, Beds
Tel: 01767 223864
email: sales@thedigitalforge.co.uk
website www.thedigitalforge.co.uk
Neil_Cross
If I'm understanding the problem correctly, isn't this now resolved in Inv2015? If I can get the image attached, when selecting the H or V constraint and then mousing over a point, it gives you a tracking vector showing the orientation and confirming that it is the wrong constraint.  Whilst it doesn't make it obvious before choosing the constraint, it stops you now from using the wrong one and having to undo?
sales
There's a lot of talk about this issue - it could be so simple but is currently frustrating.
What could be easier than applying a horizontal constraint to make the line horizontal ?
Tags (2)
graemev
Consider a map.  No matter which way you view it, North is still North.  The sketch exhibits the same behaviour.  No matter which way you view the sketch, vertical is still vertical.  If the view of the sketch was rotated 30°, should a vertical constraint now be at tha same 30°?  No, of course not.  Why should a view rotation of 90° be any different?
LT.Rusty
Graeme, the thing is that vertical and horizontal are not consistent.  They depend on the orientation of the plane itself, how it was created.
graemev
L.T.Rusty,
Yes, exactly, just like a map.  I see no reason for Inventor sketches to behave differently than they do now.
DWhiteley
dan_szymanski
Status changed to: Accepted
Accepted idea [56640]. Thanks!
dan_szymanski
Status changed to: Gathering Support
Hi, this is a duplicate of another Idea that is very similar.  The key point would be to enable to configurable shortcut to toggle between horizontal/vertical constraints.  Please cast your votes to the Master Idea here http://forums.autodesk.com/t5/ideas/v2/ideapage/blog-id/v1232/article-id/5219  as it currently has more kudos. Thanks! -Dan
mike.4life
This is a really great idea, hope we will see this in the next version of Inventor, I vote for (CTRL)
Timmy_Stalnacke
It would be good to toggle between Horizontal and Vertical constraint by using shift.
Like Horisontal becomes vertical and reverse.
Best regards.
Tags (2)
mcgyvr
Based on quite a few other programs I've used it seems that the space bar is commonly used as a "toggle" button.
I really like this idea but suggest it be the spacebar... (its a bigger/easier to hit button too)
Timmy_Stalnacke
You got a point, but I’m refer to Autocad commands that often reverse by shift tab.
scottmoyse
I'd prefer to use Tab. I think this may be a duplicate idea.
SharkDesign
I have the same problem.
I'm sure I never had this issue with 2014. Did the view cube behaviour get changed between releases?
mcgyvr
Well now we will need an option (in the customize section where you setup hotkeys,etc..) to select which button will be used to toggle so we are all happy. 🙂
Spacebar is much easier/quicker for me to hit..
stuartmp
Great Idea, I use this all the time.
It has been improved in 2015 (using a dotted guide line accross the screen to you can see the direction)
but the addition of using shift to switch is a great idea.
TheUnknow
Love the Idea, I vote for "TAB"
