hatch object api
hatch object api
Can you add access to hatch object through API or force Inventor to use only 45 or 135° hatch.
Thanks in advance
7 Comments
Would be great if this could be added... In my case i need to set a few hundred hatches to 0°... one by one now...
Currently it is not possible to access the hatch angle through iLogic or the API.
Modifying the current style's preset value for "Section Hatch Angle" isnt sufficient when a view gets rotated.
I wanted to make a simple iLogic or API script that would set all angles in a particulare view to the same hatch angle, but currently iLogic nor the API support access to setting hatch angles.
Please add this
Original question post about the subject: http://forums.autodesk.com/t5/inventor-customization/access-hatch-angle-through-i-logic/m-p/5779342#...
Tags (6)
Great idea, Its a pain to do it manual but sometimes essential.
I've been searching in API for this too
Please add this even though it doesnt get that many kudos as most mainstream things
Its a little work and you get many new apps in the appstore im sure.
demuff
We really need to be able to do this not only to set the hatch style/angle but also to set the hatch color for large assemblies with section views. Currently extremely tedious to go part by part.
Peter_Schulz
Great Idea, but not only for existing section view hatches. Add sketched hatches API too. Not everybody needs color filled areas like it is available already.
kmiller
Hi there,
We are trying to programmatically (through iLogic) apply a hatch fill to a sketch using projected lines from a drawing view.  We have all of this done and apply the fill by adding sketchfillregions.  however the fill is always solid.  My hunch is that the pattern of the hatch itself is not technically stored as a sketchfillregion and/or the api just doesn't allow for users to access this type of information.  I believe similar to what is discussed in this post.  Can anyone confirm that it is not possible to specify a pattern to a sketch hatch and you can only specify a solid fill with a color defined?   If you can specify patterns, scales, angles, etc.. with hatch via the api and it's not a sketchfillregion point us to the correct api object?  (we are using iLogic, but if we need to use normal API coding objects/methods that is fine too)
Thanks.
