Show only
Search instead for
Frame Analysis - Display the Displacement in the x, y, and z directions
The Frame Analysis results show the max resultant displacement.
It would be useful having the option to display the displacement in the x, y and z directions to determine, for instance, what the vertical displacement is.
This is an older thread but I have the exact same question. Is it possible for inventor frame analysis to show the displacement components in the x, y and z direction? I am currently using Inventor 2016.
When working with DNV 2.7-1 (2013) it is required to calculate that no element has a deflection greater than 1/300 of its length. We usually do this via the X, Y, Z of each node in FS2000.
The nodal displacement should be included in the report.
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found
that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
Any news about displacements in x,y, z direction? I am also not able to find a displacement diagram for individual beam. There are only stresses, forces and moments.
Hi there, same question I'm wanting to ask. And I actually started a new thread when failed to search one. I'm an engineer working on designs and it is very important to know the deflections in each axis as most of the standard books requires specific deflection on both lateral and vertical directions respectively. I hope Autodesk will include this in Frame Analysis. Thank you.
I am also trying to figure out the components of the displacement after doing a stress analysis. From what I see there isn't a way to do this. If anyone is able to figure it out please let me know. I will keep figuring it out in the meantime.
