Inventor has the ability to link weld symbols to fillet welds modeled in the weldment assembly. This could be a huge help to my company, dramatically reducing the number of mistakes in our weld callouts, or weld callouts missed entirely. Unfortunately, in its current state, we can't use the feature.
This is because the system is based around displaying as decimals, while most fabricators prefer to see fractional weld sizes. As a result, we are forced to manually enter our weld symbols on the drawing just like we would have done in AutoCAD.
Having one item (weld symbols) be so manual while so much other annotation is automatic tends to lead to errors. Users just simply forget to go fix the weld symbols, because everything else is so automatic, and it doesn't feel like the weld symbol tool should be any different. In my search for a solution to this problem, I saw requests going back to at least 2005 for this feature - I think it's time to close this gap.
I think the easiest way to handle this would be a unit format option in the Weld Symbol style. That way, if needed, users could set up fractional and decimal styles just as they would with dimensions. To avoid messing up the workflow of anyone using the symbols as they currently are, the default setting could still be Decimal.
