When you use a Flexible Hose style with no fitting, I can make the routing selecting the work points or the, one after the other, but, if you use a style with start and end fittings, you can just select one of this intermediate points or component geometries, then you need to add each single additional node and redefine it.
It could be useful if you could select all the intermediate points you need.
