Fence and Cutout Shape editing of Detail Views
Sometimes when creating detail views I forget to select the correct Fence and Cutout shape. To correc this I need to delete the current detail view, which I've already annotated and create a new one. it would be nice to be able to simply modify these attributes of the detail view AFTER I've created it.
8 Comments
karthur1
jtylerbc
And at least one more, which also already refers to karthur1's idea in the comments:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Detail-View-Boundary-post-placement-modification/...
Yet somehow none of them are marked as Duplicates.  If you see this idea and vote for it, please vote for the older submissions as well - dividing up the support between multiple threads isn't good, since it can make it look like fewer people are voting for the idea.
chris.r.goodrich
Community Visitor
If you right click the detail bubble that was created, there is an option under the 'options' tab to change the cut out style.
AndyWallace
I do not see an option to change the fence type in right-click options of either the fence or the detail view panel. Where are you seeing the option? Andy (Inventor 2016)
Chris.Goodrich
Community Visitor
I realise this doesn't solve wanting to change the shape of the boundary, but does allow you to change the fence/cutout settings
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
arne.dir
That it is not possible to change a simple ting as a Cutout Shape is strange.
