Show only
Search instead for
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found
that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
This is a feature I would need a lot, and have missed for close to two decades already. I do lots of FEM analyses in Nastran of assemblies, and generally in FEM it's good practice to reduce the model size by utilizing symmetry as much as possible. Often, you need a quarter of the original model (or less), and the simplest way to achieve that would be to sketch a square or triangle with one corner in the symmetry plane intersection and extending over the whole model, and then extrude it using the intersection tool, which however isn't selectable. So, instead I need to draw the opposite geometry (a three quarter geometry covering everything that needs to be removed), extrude that one using the subtraction tool, and hope I don't need to divide the model any further.
There are of course other ways to achieve the same end result, but all of them are more complicated (if I haven't missed anything). I don't know much about programming, but this seems like a simple thing to implement.
