Show only
Search instead for
Submitted byAnonymouson10-01-201410:41 AM
Status:
Archived
Exporting flat pattern bend lines
When exporting a flat pattern face into auto-cad an option to include bend lines for scribing would be a great feature instead of doing a save copy as into auto-cad format and manually setting layers.
Maybe I'm not following, but the flat pattern being cut out is not going to have those lines on it correct? Someone would then scribe the lines on a cut out flat pattern?
Why wouldn't you just make a drawing/idw file of the flat pattern with lines and bend direction? What would you use the file with the bend lines on it for?
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found
that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
