Show only
Search instead for
An explanation for what you are wanting to do with these items in Inventor would be helpful. Several of them don't seem to fit into normal Inventor workflows, at least at first glance, so it isn't immediately obvious why you would need them.
Others, depending on what you are trying to use them for, may already have a rough equivalent (ex. "Convert to solid" in AutoCAD could be similar to "Sculpt" in Inventor, some applications of "Extract Edges" would be equivalent to "Project Geometry", etc.).
Something else: Convert 2D sketch to 3D. I vould like to Circular-Pattern of 3D sketch (line and vertex, closed objects) next to Mirror!
It would be good extend "Silhouette Curve" to solid body edges and planar or opened surface.
Orthodox boolean operator and friends would be fine... everything is rigorous... I would like to concentrate only my work. If you learn the choord system proper use in autocad you can create everything, but not truly parametric...
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
