Drawings - Dimension to Apparent Intersections With Arcs
In the drawing environment, we can easily dimension to the apparent intersection of two lines, and Inventor automatically provides the the extensions.  This functionality is not available when one or both of the intersecting elements is an arc, leaving the user to laboriously create a view sketch with the required extensions and a point at the intersection, which can then be used for dimensioning.
I propose that the current intersection dimension functionality be extended to include circular/elliptical elements.
  - sbixler
6 Comments
timdown73
Agreed, this would be a great addition.
rmerlob
I agree something´s are not okay when dimensioning intersections.
For a super-related idea and comments refer to:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Improve-Drawing-Intersection-Marks-and-dimensioni...
RM
MikeKovacik4928
Here I am almost 4 years later, struggling with the same problem.
Can't understand why autodesk haven't implemented this yet!
See my post and screencast at
https://forums.autodesk.com/t5/inventor-forum/creating-a-virtual-intersection-dimension-with-non-lin...
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
SSNE302
Another 4yrs on (8 from the original post...) and here we are still fighting to deal with this exact same problem.
moeman69
Still not added! Come on......
