This is about the following situtation:
I have some models which are based on skeleton modeling and where the actual parts are modeled at the position where they are in the assembly. When the skeleton part is changed the parts will update and their orientation related to the origin planes can change. This is where the problem lies, on the drawings of these parts the views are all skewed after an update.
I would like to have a possibility to tell Inventor that a view on a a drawing should stay aligned to a specific work plane. I know views can be rotated and set so that a specific edge will be horizontal or vertical. However any projected views will still be skewed after the part is updated and the orientation changes.
Related post: http://forums.autodesk.com/t5/Autodesk-Inventor/Keep-drawing-view-aligned-to-workplane/m-p/3559028
