Do not move all the points in a non-constrained 3D sketch
Enable the feature “3D move/Rotate” to move only the selected point without move the other non-contrained point in 3D sketch (as 2012 and before).
5 Comments
How? Is it possible to Enable the feature “3D move/Rotate” in application option or any thing similar? All points move if you move one point. Must be some kind of error that not been solved. I can create line in 3 d sketch with precise inputs. But if I do one point wrong I have to erase the line and start from beginning. And if I have to justify one point on the 3 d line I have to erase and create a New. This is so frustrating, It`t one of the basic tools in 3d that does´t work in Inventor. WHY?
cecephakim
Community Visitor
I  have the same problem
EdHa
i also have same problem, this is clearly a bug
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
