Do not allow "Enter" to exit "Hole" while setting reference distances
This is such an annoyance! When I use the "hole" widget to establish drill points on a face, and establish reference dimensions, I should not have to click on the green checkbox in the dimension itself in order to complete that part of the configuration.  I should be able to press enter and keep moving, but instead it finishes the hole tool altogether often requiring me to delete the hole and start all over.
It is very un-user friendly.
6 Comments
While using this command you do not need to press enter or use the green tick. once you have entered the desiered vaule you can simply select the second referance edge.
Please try this out and let me know how you get on.
PS. what version of inventor are you running?
RobertWK
The point here is that most functionalities allow "enter" as a means to input data, and we have been accustomed to that for a long time.  With "enter" exiting the operation and calling it complete, it goes against the grain of behavior that we have all learned.
It shouldn't behave this way.
Mark_Wigan
i think that the hole widget needs improvement
a_sima
That's right, and not only this dialogue box needs improvement, say in moldyng environment, after placing the plastic part one has to rotate the part, give the required angle then, by the nature, it confirms the value with enter key and nothing rotates, First you have to move the hand on the mouse, click the tick mark and then click ok, why enter in this case could not perform both accepting the value and finish the operation?
dan_szymanski
Status changed to: Accepted
dan_szymanski
This idea has been implemented within Autodesk Inventor 2019. Special thanks to everyone who cast a vote for it.
