I'd like to have direct access to a sheet metal part flat pattern model.
Currently, the only way to get a sheet metal flat pattern model out of Inventor for a CAM system is to export (Save Copy As) the model file as SAT, DXF or DWG.
When changes are made to the part and the flat pattern updates I have to re-export the flat pattern model file.
When this is done, the exported model file is a different file... and requires me to completely re-program the part using the CAM system.
Please provide a method to allow direct, associative access to the flat pattern model.
Brian
