I use a laptop and change locations and each location has a different monitor setup. Dialog windows are always popping up out of view because Inventor uses the last location of the window, even if it will appear off screen in the current monitor set up. This happens with Vault as well. It would be nice if these dialog windows would open where they can be seen.
