Design Assistant should create a log file for errors found similar to the way Task Manager does when migrating files.
We all know ( & hate) that Design Assitant often takes a long time to parse files to make changes to file names that are referenced by many other files, etc.
To add insult to injury, a dialog box comes up with only a small portion of the errors it found when it finishes the task. The last item will have a " ..." at the end implying there are more.
If there are a lot of errors you have to fix the first set found, then re-run the Design Assistant again to get the next set & again for the next set.
This is extremely time consuming & frustrating.
Design Assitant is over due for some updating.
