Design Accelerator/Content Center Part as "Template" for Placing Another
I'd like to be able to RMB on an existing Design Accelerator (DA) and/or Content Center (CCL) part and place another instance.
I'd like to be able to place the new copy as it is, or be able to make changes to size or type.
I'd also like to be able to place it using the methods offered when I place a CCL part for the first time AutoDrop
In addition, I use the Design Accelerators (DA) as much as I can and would like to have access to the selections, placement methods & calculations for the new one.
Seems like I should be able to RMB on an existing DA part, (a bearing for instance) choose "Edit Using DA" and have access to a "Make copy" option (checkbox?). this would get me a quick way to place, edit, calculate & constrain an identical (or almost identical) component quickly and easily.
Hope this makes sense,
Brian
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
