Show only
Search instead for
From the What's new of the new release of Inventor 2016..
"Custom Balloons in Balloon Styles
You can use a sketch symbol as the default balloon shape in a balloon style. In the balloon style, switch on the Used-Defined Symbol button, and select a symbol from the list."
Is there a way to create multiple balloon styles, each with different custom shapes? I can create multiple styles, each with different stock shapes and I have created a style with a custom shape but I don't seem to be able to make multiple styles all with different custom shapes. Thanks!
This idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it. In Inventor 2016 you can use a sketch symbol as the default balloon shape in a balloon style. In the balloon style, switch on the Used-Defined Symbol button and select a symbol from the list. NOTE: a local symbol must be present within the document in order to be referenced within the style.
