Curved Frame Generator Member Length
Is it possible to change the way that the length of curved frame generator members are measured?
Currently, it seems the length is measured on the centerline of the steel.  In a fabrication shop, this is not a practical way to measure these members.  For example, on a wide flange beam, rolled the easy way (like this), our shop would measure the length along the web of the beam, rather than the centerline.  As a result on some curved steel shapes (HSS for example), the G_L parameter that Inventor generates can be off by quite a bit.
Our work-around has been to add a sketch to the frame generator part, and use a driven arc dimension that replaces the G_L parameter to pull the cut length for our parts list/BOM.
It would be great if this could be addressed in a future upgrade.
Thanks, Dan.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
