I'd like to reuse an existing part which is adaptive in an assembly.
Neither iLogic "Design Copy", Vault "Copy Design" nor Design Assistant clears adaptivity upon copying such a part.
Regardless of which method I use to copy the part, Adaptivity is not cleared on the copy, and as such, not available for the new part.
When the newly copied part is placed in an assembly, adaptivity for that part is not available as an option from the iProperties -> Occurance tab nor the Browser Right-Click menu.
Seems to me clearing adaptivity should be part of the copy design process for all of these methods.
Same results in 2014 & 2015. Is there a workaround for this limitation?
