Update Drawing - word wrapping in table header
An improvement to the table setting in Inventor drawings would be the ability for the heading in tables to word wrap.
26 Comments
dvsmiller9
I agree.  I've had to fake the header text wrap by disabling the header row and using the first data row as a psuedo header.  It would be better if header rows just supported word wrapping.
andrewdroth
Yes, this issue has been present too long.
dan_inv09
I'm, right now, trying to do as dmiller says but I'm also trying to use Units Formatting so I've got a column called Incompatible Units Error now.
dan_szymanski
Status changed to: Accepted
Accepted idea [US-50931]. Thanks!
ca-d.one
It would be very welcome if you could look at the components / modules in the browser if they still have freedom or not. Comparable to the browser display "Fixed"
Es wäre sehr zu begrüßen, wenn man den Bauteilen/Baugruppen im Browser ansehen könnte ob sie noch Freiheitsgrade haben oder nicht. Vergleichbar mit der Browserdarstellung "Fixiert"
dan_szymanski
Status changed to: Gathering Support
Hello, this is a duplicate Idea. The Master idea can be found here: http://forums.autodesk.com/t5/Inventor-IdeaStation​/Change-icon-of-fully-constraint-parts-in-assembl... Please cast your kudos to the Master Ideas as to not split them. Thanks! -Dan
dhagen
Would like the Header to Automatically wrap if the column is not wide enough.
barry.ashcroft
column head on general table- require text wrap
Tags (1)
dvsmiller9
Similar to this idea http://forums.autodesk.com/t5/inventor-ideastation/update-drawing-word-wrapping-in-table-header/idi-...
which was Accepted.  Gave kudos because it's still a good idea.  Wondering when it's coming.  Accepted May of this year.
Bazash
I used DWG template and jumped over to autocad the settings were similar and as restrictive.
in the end i drew the table out in autocad then jumped back into inventor.
dmiller has the best way in hindsight. just drop the header and use the firt row as header as the cells use text wrap
dan_szymanski
This is in fact a duplicate of http://forums.autodesk.com/t5/inventor-ideastation/update-drawing-word-wrapping-in-table-header/idi-... Please be sure to visit the other Idea and cast your kudos there as to not split the votes. Thanks -Dan
Kyle.Arnold
I don't really understand the hold up with this... They've had complaints about table headers not wrapping since 2009 (Just Google the issue).  It really can't be that tough to program right?!?!? I mean the other cells wrap just fine!
ihiengdept
I agree with other posters.  It bothers me that a "feature" like this can't get addressed in a reasonable time frame.  It should have been there from the beginning.
Since 2009:
http://forums.autodesk.com/t5/inventor-general-discussion/word-wrap-in-table-column-headings/td-p/31...
http://forums.autodesk.com/t5/inventor-general-discussion/word-wrap-a-column-heading-in-a-table/td-p...
dan_szymanski
Hello this is similar request to another idea posted (http://forums.autodesk.com/t5/inventor-ideastation/update-drawing-word-wrapping-in-table-header/idi-... As such I am setting this as a duplicate.  Please be sure to cast a kudo for the Master idea. Thanks.
brent_e_barbour
It’s now 10-16-2015, over 6 years since this issue was a suggestion and was accepted over 3 years ago.  NASA's talking about sending an industrial 3D printer to Mars to begin constructing structures for future colonies. Any idea when Autodesk is going to implement text wrapping capabilities in table headers? This is embarrassing, I mean come on!
Whichever programmer was assigned “column header text wrapping” step away from the water cooler and GET BACK TO WORK!!!
lee.jago
Observer
As said previously, it makes tables look unprofessional and scruffy.
A text wrap feature would be greatly appreciated instead of a "work arround"
dan_szymanski
This idea has been implemented within Autodesk Inventor 2017. Column headings wrap to a minimum width to accommodate the largest word in the column. Table headings wrap to the minimum width of the included columns. The enhancement is available within all table types (parts lists, hole tables, generic tables, revision tables, etc.).  Special thanks to everyone who cast a vote for it.
ToddPig
Please add the ability to wrap text in column headers.
For example, in Excel you can use the combination of increasing the row height and then use wrap text to decrease the size of the table (making it easier to read as well as removing tons of dead space).
dan_inv09
According to
https://synergiscadblog.com/2016/03/28/autodesk-inventor-2017-whats-new-information/
  • *Word wrapping is now supported in the columns and headings of a General, Parts List, Hole and Revision tables
for 2017. What version are you using?
dan_inv09
Here we go, (Wow it's hard to find you way around the Autodesk website now!)
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2017...
Automatic Text Wrapping in Title and Column Headings in Drawing Tables
The General, Part Lists, Hole, or Revision tables in drawings, columns, and headings now support automatic text wrapping. Column headings wrap to a minimum width to accommodate the largest word in the column. Table headings wrap to the minimum width of the included columns.
Tip: Legacy drawings, when first opened, continue with the legacy behavior. To change a table to include the new functionality, open the Edit Table dialog box and click OK to allow for text wrapping.
