Changing dimension names can be difficult when you have to go to the Parameters and remember the name of the dimension so that you can change it. It would be useful to be able to change the name of the dimension from right inside the dimension dialog box as you create the dimension. It would also be useful to be able to change the names of parameters in other features like the Hole Feature Dialog Box and the Rectangular/Circular Pattern Dialog Box.
