Centre Point Rectangle
Can we have this available in the 3D Sketch environment as well as the 2D sketch environment? (just as it is with the competitors product).
3 Comments
thyzsz
And, can you made it possible that if you made an Centre Point Rectangle could also use the offset function.
Now: If you use centre point rectangangle: You can only offset one entity, not a loop.
If you use 2- point rectangle, it will recognize a loop with the offset command.
dan_szymanski
dan_szymanski
Status changed to: Gathering Support
