Batch export of dxf from assembly environment - optimized for CNC
Many times I need to export sheet metal flat patterns referenced by the assembly to dxf for cutting or laser machine. I know I can program this in VBA (actually I did) or purchase it on Autodesk exchange apps from Micrographics , but I think it should be standard part of Inventor. This Micrographics application has also nice additional features - removing center marks, replacing splines with polylines or arcs (desperately needed for CNC control ) and more. It can be very useful. Also , it should make list of parts exported , with thickness and number of pieces for export to excel.
3 Comments
leblanc2024
Hello livewire77,
I agree that a new export should be developed for sheetmetal export...  As a work around we set our dxf export options as shown in the image below.
Only having the selected layers works perfect for our Prima and Mazak lasers.
Once you set these you can save your configuration and this will remain until you change it.
Hope this helps.
Ivon
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
