The Notch, Miter, Trim etc. commands are working very well in Inventor Frame Generator - even compared to other Steel Structure Detailing Platforms.
But when it comes to standard Beam to Beam connections, Beam to Column connections etc. that are meant to be repeated several times but with different variables it is not straight in Inventor.
Apart from editable standard connections - it would be a great advantage if you could record your own ediable connections for reuse - as a macro or like.
Maybe iLogic Forms with a small icon showing the various variables?
Example from a third part platform is attached.
