Automatic center mark/center line on sheet metal cuts
When I make a simple hole in a sheet metal part, it's much easier to sketch and dimension a circle then use the sheet metal "cut" tool to create a hole. Much easier than using the "hole" tool or the "punch" tool. Unfortuantely there isn't a sheet metal "cut" option in the "Automatic centerlines" tool so holes created in this method do NOT get automatic center marks. It seems like it would be an easy upgrade to have the "automatic centerlines" tool also include sheet metal cuts that were created from circles.
4 Comments
Hi.
Instead of draw a circle, draw a sketchpoint. Use this for the hole command. It is a less clicks to dimension a sketch point then a circle.
If i now understand yours post correctly.
jletcher
It does work you just have to pick the right option in the Automated Centerlines.
 Try picking this option and it will work..
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
