Apply the same radius when consecutively drawing circles in a sketch
Quite the same thing that is done for chamfers, by example
7 Comments
kevin_park
That's exactly what I wish!!
jtylerbc
I like it.  To prevent it from becoming a nuisance when that isn't what you want, I think one of the following should also be included:
  1. Option in "Application Options - Sketch" to turn this feature off
  2. Clearing of the dimension memory when command is exited (ex.  Make a bunch of Ø5 circles, hit Esc, start circle command again, enter new size, make a bunch of the new size circles.)
seth.moffit
I like this! You could also allow the user to toggle through the recent imput vaules with the arrow keys.
You can draw all your circles, then window select all of them, then select the equal contraint. Then just dimension 1 circle. All are equal.
Your tip is great Doug!
However, it doesn't mean that my request becomes superfluous.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
