I have seen many people complain about it but strangely not one post on the ideastation...
There really needs to be some method of disabling Autodesk 360 in Inventor for the user base that doesn't want to use it.
Personally I don't mind it, but I know many clients that do not want to have the Autodesk 360 drive in their "favourites" by default.
In Truth this should be the same for all products, If the client doesn't want to use the function don't force it on them.
It Could be an option in "Options" or a Right click "Remove from Favourites".
Currently if you accidentally Click on the grey area it Automagically (that's right its magical...) brings up the login dialog box. Now that wouldn't be an issue if the box popped up in front of everything... instead it appears behind other windows making it a pain for anyone not using Autodesk 360 to switch folders.
That's the main reason why I'm posting up here in the hopes that the issues gets looked at, I would like to see the option to remove the link altogether so its not an issue, but if they fix the random login pop up issues that would also work.
James
