Allow Symmetric Component Patterns in Assembly Environment
Add the "Symmetric" option to the Component Pattern dialog box.  This would allow for the correct number of components to show in the BOM when the pattern is created.  Currently, I have to use both directions to accomplish this and in turn causes my component count in the BOM to be incorrect.
Before:
After:
5 Comments
Hi!
I want create a symmetric rectangular series of components but I can't start selecting the central component.
I can use it only for make a rectangular series of holes (with midplane) selecting the central hole.
Is it possible?
Thank's
Nicola
BryanKelley
Status changed to: Duplicate
This idea is based on the following link. http://forums.autodesk.com/t5/Autodesk-Inventor/Bi-Directional-Patterning/m-p/3687130#M453320 Status: Duplicate Hello, I am marking this as a duplicate of an Idea entitled "Midplane Rectangula​r pattern in an assembly " http://forums.autodesk.com/t5/Inventor-IdeaStation/Midplane-Rectangular-pattern-in-an-assembly/idi-p... Which in turn has been Accepted as [US21780]. Thanks!
Oesh01
Thanks for the update BryanKelley, but I do not believe that the reply marked as the "solution" accomplishes the same thing as what I am suggesting.
mcgyvr
Bryans link just got truncated.. This is the duplicate request..
dan_szymanski
This Duplicate idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it.
