Its great that we can use the Parts List filter to work with View Reps - however this cannot control the quantity column of the parts list.
For example, if Assembly X has 10 instances of Part A placed inside it:
- ViewRep 1 has 5 instances of Part A visible.
- ViewRep 2 has 3 instances of Part A visible.
In the drawing, when using the Parts List filter and choosing ViewRep 1 as a filter, then quantity column for Part A should reflect 5. When choosing ViewRep 2 as a filter, then the quantity column for Part A should reflect 3.
While iAssemblies will acheive the same result, it is sometimes too much work to configure to get what would be a very simple result.
