Search box in the FX Parameters Dialog Box
The subject says it all. Can you put a search box in the Fx Parameters dialog box. Some mature parts/assemblies can have pages of fx parameters and it would be convenient to type in the name, with wild cards, of a parameter you're searching for. At that point, the table would only display parameters that fit the criteria.
It appears to me that you are using DevExpress tools to create portions of your UI. Their table object has that functionality built into it. If that is correct, can you at least make it an option for the "Parameter Name" column?
Thanks.
8 Comments
gcross
Wouldn't it be great time saver to be able to do a search in the parameters dialog rather than scrolling through zillions of dimensions & comments.
Gary
Tags (2)
inv.ideareview
Status changed to: Archived
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so.
manojrko111996
Observer
Kindly add the search box column for fx parameter..
It is very Usefull for all inventor users..
Ben-Cornelius
eric.mathews7BV6E
As it turns out, I also use DevExpress tools for development. By dumb luck I discovered that this functionality already exists. Open the Fx parameters dialog box and hit "ctrl f" and a search box appears. My only complaint: it locks Inventor up every time I use it.
Yijiang.Cai
Many thanks for you posting the idea, and tracked as [INVGEN-61709].
dan_szymanski
Status changed to: Accepted
Accepted idea [INVGEN-61709]. Thanks!
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2024.2. Please review the Inventor 2024.2 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
