This annotation objects exists in other 3D Moding programs such as SolidWorks and would be a welcome addition to Autodesk Inventor. Right now in order to add a conventional dowel symbol to a drawing, you have these options...
1. Create a Sketched Symbol - Make a symbol that when you place it, you can choose the size you desire for the dowel.
2. Install an addin called Quick Dowel - this is a more automated version of the first option but falls well short since any change to the modeling geometry will not change the actual size of the dowel symbol in either 1 or 2.
3. Create a Sketch on the View - lastly you can create a sketch on the view in the drawing and then project the edges of the dowel hole. You then have to draw 4 lines and create two solid fill hatches per dowel. What is great about this is it will automatically update when size changes, what is horrendous about it is that it is VERY time consuming.
