Ability to create sheet metal contour roll feature through API
Inventor API does not expose the "Add" method for ContourRollFeature object. Therefore, a sheet metal contour roll feature cannot be created using the API.
4 Comments
inv.ideareview
hanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
john_valdesH9N85
Unfortunately, Inventor does not currently provide the API needed to create sheet metal components from Codeware Software Compress. Several years ago they (Codeware) submitted a request for this feature. Meaning, this feature is being limited by Inventor. For Engineering to go more in the future, this releasing of the API architecture to Codeware will help all Inventor users like myself to create products faster.
alewis
Yes, this would be very helpful and save time. The alternative is to make a copy of the vessel. Remove the pad, increase the shell size to the diameter of the pad. Export, etc., etc.,etc.
