Ability to change View Rep AFTER inserting exploded view
We need the ability to change the View Rep in the IDW for exploded views (created from IPN files) after they are placed.
As it is,  once you commit to a View Rep & click associative when you place your exploded view on the IDW you cannot change it to another View Rep later. All you can do is turn off associativity & then you have to manually change visibility. This is an invitation to potentially having your exploded view out of sync with the other views when the View Rep gets changed on those.
The IDW environment could be so much better with this long overdue fix.
