When producing a drawing you can manually individually change the visual style to hidden lines but not shaded or unshaded which you should also be able to do. You can aslo manually change the layers of parts but is a slow process epecially if you need to do this on other drawing views. I think you should be able to save these with the model in the view reps epecially as you might need different configurations of theses.
