The goal here is a single template, with a single company standard, set up and managed by the CAD admin , where the users can switch the "drawing style" with one click, rather than having to remember to switch dim styles, then switch balloon styles, the leader styles, etc. (see example image below).
Do you struggle with the Styles and Standard editor? Or are you a CAD Systems Admin who understands the Styles and Standards editor all too well, but have users who get a bit turned around in there and muck things up a bit?
If so maybe this idea is something you'd find useful.
I think this idea would need A HUGE amount of support from the Inventor community to be implemented, so ask questions, leave feedback, etc. but kudo it if it sounds like you'd be interested.
So here's the idea:
Using this strategy let's say you want to create a "Sales Drawing". You would open the template (you only need one now) and switch a new "Drawing Style" dropdown to "Sales". And then the dim styles, the text styles, the balloon styles, etc. would all update at once.
If you needed to create a "Detail Drawing" you would open the template and switch the "Drawing Style" to "Detail".
If you needed a "General Arrangement Layout Drawing", you would open the template and switch the "Drawing Style" to "Layout".
If you need a _____________ drawing.... , well whatever the style of drawing you often create, you set those up as a collection of styles (like the Object Defaults) , name it what you want, and that becomes your list of "Drawing Styles" that you can switch between quickly, without having to dig into the Style and Standards editor.
That's the short version of this idea. Kudo it now and get back to work, or keep reading if you're still interested.
Long version continues below:
As far as I know this can't currently be done this way without:
a) using multiple template files ( each of which has to be managed individually anytime a style is updated, or a title block is update, etc.)
b) users stepping into the Styles and Standards editor (which we don't want them to do if this is being managed by a CAD Systems Administrator)
c) using some customization
This approach is the correct way for "enterprise" standards to be set up, used, and managed, but there is not a built in way to do this currently.
Generally these things are true:
Using this "single template, single standard setup" ensures that the users start out correct, and makes it very easy for the these things to be managed.
Ultimately, what I would like is a "Drawing Style" drop down that switched between multiple Object Defaults collection in "one fell swoop", as in the mock up above. This makes it easy and intuitive for the user.
I do something like this currently with ilogic by presenting users a pop up containing a list of "Drawing Styles" to choose from when they open the template to start a new drawing. Then the code sets the active dim style, parts list style, balloon style, and so on, so the user never has to worry about any of this. Some of these "Drawing Styles" resize the sheet and change out title block, standard notes, and some other things as well. If the user needs to change from one "Drawing Style" to another, that can be done as well.
Currently, I know of no way to do this without:
Employing this single template, single company standard, multiple Drawing Styles approach simplifies things for the users, the CAD Systems Admin, and just makes a lot of sense once it's in place, but it seems very few places connect the dots in putting this together, because currently it can't be done with out some customization.
Pretty much everything is already in place, we just need to create multiple Object Defaults to control these "Drawing Styles", and provide the dropdown to allow the user to change between them quickly without entering the Styles and Standards editor.
In addition to the "Drawing Styles" drop down the other missing piece is some ability to control the sheet size in the style, so I think an addition to the Styles, such as a new Sheet Format Style, would provide this.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
