Make your voice heard!
Please take our short survey and let us know about your experience and satisfaction with the Inventor Standard Tutorials.
With improvements to technology we are now able to drive better learning through the Interactive Tutorials which run inside Inventor.
As we move strongly in this direction we want to understand the importance of the existing standard tutorials in satisfying your product learning needs.
Please take our short survey and make your voice heard!
Standard Tutorials are posted online and you follow along using your web browser.
Interactive Tutorials run inside the Inventor application and lead you through the tutorial in a side panel with step by step video, supporting text and model files, and in-canvas visual clues linked to the text.
Follow this link – Take the Survey
Thank you,
The Inventor Learning Experience team
Do we need to increase graphic card memory for Inventor 2014 for better performance?
A better Graphics card usually improves performance, more RAM is better. Best performance booster I've found is a good SSD drive for your OS and software. IMHO
Frank
I just made it!
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
