Heelo guys, can anyone help me with a little issue, I have an assembly which has components mated to a radial surface, I need to locate the center of a round slot against an axis, I have X Y coordinates, how can I constrain that part to those X Y coordinates? Thanks in advance!!.
Attached is a picture of the assembly.
I would use Assembly Constraints instead.
Pattern Workpoint (or other logical feature in the shaft part).
Component Pattern in the assembly.
Attach your assembly here if you can't figure it out.
I think there is a similar example in this document
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
If I understand your issue correctly, I have had more luck using this command when it comes to situations like yours.
@Cadmanto wrote:...I have had more luck ...
I prefer logic.
The OP needs to clarify the problem statement through active discussion.
