Inventor Forum
Wrong exporting from Autocad to Inventor? or ???
10 REPLIES 10
Message 1 of 11
Eugene777
941 Views, 10 Replies
Hi there, i have some difficulties in Inventor .
I have file in .mm ,when i open it in  Autocad , it display correct dimensions , in .mm (for example one dimension is 80mm) , but if i open the same file in Inventor, the same dimension ( 80mm) display 80inch.
What wrong with it?
PS. I have made Tools - Documents Settings - Units -mm  and it doesnt help
10 REPLIES 10
Message 2 of 11
JannieHunter
in reply to: Eugene777
Will you be able to share the file so I can have a look?
Jannie Hunter
Modena Design Centres
South Africa
011 463 1553
Message 3 of 11
Eugene777
in reply to: JannieHunter
Here is
Message 4 of 11
mcgyvr
When you open it does it give you options? In there you can set "detected" units or specify other units
Message 5 of 11
Eugene777
Message 6 of 11
Eugene777
in reply to: mcgyvr
NO, its not give me option when I open it
Message 7 of 11
Eugene777
Guys, I cant found solution yet ((((( Give me advise to solve this
Message 8 of 11
JDMather
No, it is 80 inches in AutoCAD, not 80mm.
Open your dwg file in AutoCAD
run the -dwgunits command (with the minus sign)
What does AutoCAD say the units are?
Message 9 of 11
Hi Eugene777,
It's not clear to me what you have tried so far, but I think these steps should work for you:
1) In AutoCAD select the L profile and then right click and choose Copy (or press CTRL + C on the keyboard)
2) Next, switch to Inventor and make sure you have a new part file created and a sketch active for editing.
3) Then right click in the sketch area and choose Paste (or press CTRL + V)
4) Next, right click and choose Paste Options.
5) In the Paste Options dialog box, choose the Specify Units option and set the drop down box to the correct unit, then click the OK button.
6) Then, click in the sketch area to place the pasted geometry.
Note too that you would be well advised to create a Sketch Block from your pasted geometry.
I hope this helps.
Curtis
Message 10 of 11
Eugene777
in reply to: JDMather
Its says Unit for leght (1) , but i downloaded this file from German CAD site and they dont use inches . I also downloaded another file with C-Profile with dimensions in .mm
Message 11 of 11
JDMather
@Eugene777 wrote:
... but i downloaded this file from German CAD site and they dont use inches ...
They use inches - they just don't know it.
AutoCAD was known as a "unitless" program - users called "1" whatever unit they wanted.
As you see now, units are now stored in the file.
You can convert AutoCAD (follow command line with -dwgunits command) or in Inventor.
