Since version 2013 we got problems with how colours appear in the drawings.
They turn very dark.
Please see the attached files.
It's important to us that white really shows as white.
Solutions?
regards
Emil
Solved by Emil.Lewandowski. Go to Solution.
It looks not reproducible, and could you attach the dataset for more investigation?
Here are a sample file.
Emil
Hi Emil,
Thank you to report this issue to us! With investigation, it will work fine when changing the lighting style from two lights to default. Anyway, this issue has been logged as 1469375 in database.
The Default Lighting Style were missing in my migrated Library but found the right xml-file in the original installation.
Now it works fine after adding a light to the Defult setting.
