Hello frineds. I have a problem to make wrap of rectangle on surface showed below. Is there any other way which could do this. Remember, I don't need to project but to wrap sketch.
Thanks in advance
Solved by JDMather. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Wrap is limited to cylindrical or conic faces (or of course planar).
Hello. I don't need to emboss or decal nothing. I need to make 3D sketch which represent wraping above sketch on surface. Cross section of surface is on attached picture.
Any idea?
Danijel
Well, i made this in order to just get the contour shape.
Not sure if it's of any help, but maybe you can get some ideas out of it...
Niels van der Veer
The Netherlands
Hi!
You have only the "sample" in the cylindric face, but with this reference and a litle of maual work you achieve the "wrap result" manually.
Check it. (This is only wrapped in the "horizontal direction", but you can use the same mechanism to build it it both directions.)
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Is this kind of what you are looking for?
Hello.
Your solution is ok, I will try to use your idea for my problems.
Thank you very much.
