Hi everyone,
I'm getting close to finishing my 1st actual projects that I've modeled using Inventor and I want to basically save a copy of one assembly file so that I can make a second derivative file which is basically the same assembly with the exception of a few parts being different. My concern is how that will link up the .ipt files to it.
Will Assembly A and Assembly B use the same part files as a reference?
OR
Instead of sharing common files would assembly B create a new copy of each part in it, similar to the way a mirrored part in an assembly is saved as "_MIR:1" then "_MIR:2" and so forth for each instance?
If I delete a part from Assembly B or Replace it with another part file, will the assembly file cause an error because it's looking for the replaced part?
I just want to make sure that what I'm doing here won't wreak havoc on my files if I proceed with it!
Yes a simple copy of an assembly will still be pointing to the orginal files.
Here's the method to use ( if you're not trying to copy IDW's):
click Copy button
Select your top level from the browser:
click the buttons to configure the copy to copy, reuse or exclude parts as you see fit:
(hover over the buttons at the top of the dialog to see what each one means)
click the "Open in New Window" to make a copy of the top level, also, set name and file location for all files to be copied
