I had to recently re-install my Inventor 2011 Professional. After doing so, my work planes lost their opacity from one side. Meaning you can only see through them on one side. See the attached picture...
My question is, is there a setting somewhere to change this? I have looked everywhere.
Same part looking in the opposite direction...
Solved by JDMather. Go to Solution.
tools..application options..display tab.. pick a different color scheme.. Like Winter Day or whatever..
Color and back color for work planes are defined in registry:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion15.0\System\Preferences\ColorSchemes\Schemes\11\WorkPlaneColor
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion15.0\System\Preferences\ColorSchemes\Schemes\11\WorkPlaneBackColor
The values are composed by 4 numbers, the first 3 numbers is the RGB color, the last one is the transparency. 1 means solid color, 0.5 means half transparent, 0 means transparent.
Probably you have “0” in the last digit of WorkPlaneBackColor key.
You can set the color you prefer on your color scheme, for example the number 11 in the example here is the "Winter Night" color scheme. You can change the same settings to the color scheme you use.
@Daniela_Koloszko wrote:Color and back color for work planes are defined in registry:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion15.0\System\Preferences\ColorSchemes\Schemes\11\WorkPlaneBackColorThe values are composed by 4 numbers, the first 3 numbers is the RGB color, the last one is the transparency. 1 means solid color, 0.5 means half transparent, 0 means transparent.
So what is the file path to be able to change the transparency? Or what are the steps to do so?
In general if you do not have experience editing your registry - you should probably find someone who does.
But if you are determined to give it a go -
Start>Run>regedit for the rest you are on your own as I don't want to lead you into a mess. Just make sure you save a back-up of your registry first.
Someone else might come along and post the exact steps or a routine to edit it for you.
You can also install the SDK tool “User Tools” located in the SDK installation folder : C:\Users\Public\Documents\Autodesk\Inventor 2011\SDK
UserTools.msi
It helps to make the changes without the need to edit the registry. This set of custom Inventor utility includes the Color Scheme Editor that allows users to change the colors of a color scheme for work features and other elements in the user interface.
I have installed the SDK tool. Now how do I go about editing the said features? Work features, Color scheme etc?
You can open the ColorScheme Editor from this folder:
C:\Users\Public\Documents\Autodesk\Inventor 2011\SDK\UserTools\ColorSchemeEditor\Bin
In the dialog box of this tool, you can see all the Color Schemes and change the Work plane Back settings for your active Color Scheme. Please see attached images.
