Is there a way to do this in 14? If not WHY NOT??
Solved by johnsonshiue. Go to Solution.
Solved by mcgyvr. Go to Solution.
The ICE (Inventor color scheme editor) will allow you to adjust the transparency of the work planes front and back..
Hi! There is actually a way to change it. It is done via Registry setting. If you feel comfortable changing Registry settings. You can proceed further. Otherwise, it is better to leave them alone. Make sure you make a backup copy of the registry, so you can easily fall back.
The following key dictates how objects are colored by default with a given scheme.
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0\System\Preferences\ColorSchemes\Schemes\
\001\ should be for "Deep Blue"
By changing "WorkPlaneBackColor" and "WorkPlaneColor" to 1,1,1,1, I am seeing the following on my machine.
