Inventor Forum
Work flow to create a blank with additional material?
4 REPLIES 4
jeremy_wasserstrass
333 Views, 4 Replies
We have a waterjetand machine shop at my place of employment, and currently my work flow is to draw the parts. Then for parts that need material left for machining I create a new part and using the derive tool I place my base part which I then apply extrusions to fill the holes and use thicken to add material to the surfaces that need machining. Being a self taught user I have to ask is there a better work flow to get blanks that update with my parts in the assembly? Currently we are using 2013.
Using Inventor 2022 on Windows 10
Ideas needing support: spur gear tooth profile, rack gears generator
4 REPLIES 4
You can use Delete Face with Heal option to fill holes rather than doing extrusions.
Might look into possible iLogic solutions.
Thanks. I had to set my ribbon back to normal to find the delete face tool, definatly worth it though.
You could also use the Weldment Feature. You will have one IPT and one IAM file. Pre machining and Post machining can be shown with the IAM. This is helpful for machining after weldments as well. Take a little planning ahead of time, but cleaner.
blair
in reply to: dlmsdm1
There was a great workflow for this in last years AU2012 using a iPart. This allows for the main part to push out "versions" than have incremental steps to cover ear machining process.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
