Hi. Newbie question, but have searched.
I understand how to manipulate the visibility properties (size, shape, etc) of a work feature in a part file. I can 'autosize' it or manually select it and drag the ends/corners around. All that works just as it seems it should.
Why is it that when I create a work feature in an assembly, I can't manipulate it the same way?
Take a plane: Once created, I can't select it with the mouse. When I select it in the browser, it highlights the plane with the corner handles and all, but there is no manipulating it - even with autosize off.
Axis added in an assembly work the same way.
Suggestions?
JB
Solved by salariua. Go to Solution.
It's all working correctly. You need to change your selection to Feature Priority and then you can select them and resize them.
Can't remember when this was added as "improvements" but in 2015 it shows the plane name.
NICE!! Thanks SO much.
Appreciated.
JB
