Inventor Forum
wood rendering
11 REPLIES 11
Message 1 of 12
mech5328
2525 Views, 11 Replies
wood rendering
I would like to know where can i find a rendering with wooden boards. I have created a surface and i have added thickness and i want it to seems like wooden boards.
11 REPLIES 11
Message 2 of 12
LT.Rusty
in reply to: mech5328
Inventor ships with quite a few different wood textures.  You should be able to find something in there that works.
Rusty
Message 3 of 12
mcgyvr
Assign a "wood" appearance to it via the appearance dropdown in the quick access toolbar or via tools..appearance button.
Message 4 of 12
blair
You may wish to create/copy additional wood Appearances with the material map rotated at different angles to deal with different parts and faces to get the material orientation the way you want.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 5 of 12
mpatchus
You can easily create your own custom wood using seamless textures.
I've had great success with Wood Workshop from Spiral Graphics Inc.
http://www.spiralgraphics.biz/ww_overview.htm
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 6 of 12
JDMather
in reply to: mpatchus
Are you aware of any white papers on working with colors/textures (appearances) since the change made a couple of releases ago?
I used to be able to create a wood grain texture that went in on specified direction x,y or z across the part (regardless of number of faces transistioned). http://www.b2-design.biz/Tutorials/AligningTextures.htm
I used to be able to create an entirely transparent color.
(search here on clear&.bmp)
I could do these without any instruction or help from the "Help".
I have abandoned any work with color/textures the last few releases (whenever was changed).
Last night I gave it a try (using the Help) and about put my fist through the screen.
Message 7 of 12
blair
Try this
Delta Tau Chi ΔΤΧ
Message 8 of 12
blair
in reply to: blair
Still can't attach files from work on this new forum. Will attach a PDF on Materials and Appearances this evening from home.
Delta Tau Chi ΔΤΧ
Message 9 of 12
JDMather
in reply to: blair
Smiley Very Happy
That is what I am after - an invisible part appearance.
Message 10 of 12
blair
in reply to: JDMather
Since they went to the new forum I am unable to insert images or attach files at work or edit a post. You can't tell if a file didn't get attached until you posted it. I have even had a couple of (out-side) tech guys look at my work machine and still can't solve the problem. It's not just on IE10 or IE11 but also with Safari and Mozilla as well.
Delta Tau Chi ΔΤΧ
Message 11 of 12
blair
Here is the document I tried to post earlier. In 2013 Inventor changed how it deals with Materials and Appearances, this has carried forward in IV2014 as well.
Delta Tau Chi ΔΤΧ
Message 12 of 12
blair
We'll need the "Cones of Silence" to discuss this. http://www.youtube.com/watch?v=g1eUIK9CihA
Delta Tau Chi ΔΤΧ
